  » De 12Vdc vers 220Vac
jpb
jpb ★★★★☆☆☆ 21/05/2006, 12h12 #1
Concernant la conversion du 12Vdc vers le 220Vac :
A titre d'info voici une serie de lien
Onduleur
thread sur sg3524, pic, et livre transfo
http://www.picbasic.co.uk/forum/showthread.php?t=1846
Avec un motorola , na 1669, mc44603, 110W, 40khz, ya discussion transfo
http://www.eetchina.com/ARTICLES/20...C08_AMD_AN1.PDF
1000w-2000w, sg3524, ne555,4060 ... Schema
http://www.theverylastpageoftheinte...er/inverter.htm
I can tell you that making a DC to AC inverter is easy. briefly challenging if you want to goto 5A or higher. the difficult part is if you want to synchronize the AC to the north american power grid.
inow you need feedback to control these 3 things:
i) voltage magnitude (generally, this is constant)
ii) frequency (if you use the line frequency via a transformer within your modulation technique you won't have to worry about this item either)
iii) phase angle. this can be tricky.
some good examples of high power inverters (10kW+) with schematic and description can be fore here:
Pb acces !!!!
http://www.nalanda.nitc.ac.in/resou...e/ebooks/VT.pdf
http://www.nalanda.nitc.ac.in/resou...oks/florida.pdf
ou access ok ici
http://www.energychallenge.org/2001Reports/VT.pdf
http://www.energychallenge.org/2001Reports/Florida.pdf
15Kw sur 3 phases, ya transfo, pic, Sinus ... $1600
http://www.hot-streamer.com/hilo90m...r/inverter2.htm
12V 120Vac 2kVa, bien i2k,zip
http://www.technology.niagarac.on.c.../mcsele/i2k.htm
http://www.interq.or.jp/japan/se-inoue/e_ckt30_1.htm
convertisseur 12V vers 220V 300W, schema, pcb ..ne555,2n3055
http://perso.wanadoo.fr/f.dichamp/convertisseur.htm
Base cours
http://www.ist.jussieu.fr/~auvray/C...a_decoupage.pdf
3kva 12V vers 220V 1999
http://www.qsl.net/dg5sga/inverter.htm
et son schema
http://www.qsl.net/dg5sga/3000w_12.gif
avec NE555
http://www.uoguelph.ca/~antoon/circ/555dcac.html
Auto-oscillant dit jusqu'a 1kw ?
http://www.aaroncake.net/circuits/inverter.htm
un autre
http://w5jgv.com/inverter/Inverter.pdf
I have this UPS (Uninterruptible Power Supply) that needs a serial cable to communicate with the computer. Minuteman Alliance A425 , 425-Watt Uninterruptible Power Supply
Not really - it is a 425VA UPS (about 275 W). Here's the DB-9 pin outs.
http://www.minutemanups.com/support...ce_manl_eng.pdf
DC vers AC inverter intersil na, ups
http://www.intersil.com/data/an/an9611.pdf
et lien regroupant liste de discussion sur ce site :
Il y aussi maintenance des certains appareils ....
http://www.abcelectronique.com/foru...searchid=123769
Bonne lecture a tous.
Et merci d'indiquer vos nouveaux lien si vous en avez pour le besoin de tous.
JP
jpb
jpb ★★★★☆☆☆ 15/05/2009, 13h49 #2
A titre d'information pour tous :
Pour synchroniser un onduleur avec le réseau edf, il faut chercher vers les onduleurs dit synchrones ....
Attention aux normes et EDF ....
Merci d'indiquer des informations svp ...
